3 members (baldeagle, Eisenholtz, NJC), 71 guests, and 2 robots.
Topics128,037
Posts1,055,469
Members48,424
#1174241 07/17/2016 2:48 AM
Ok
So I have Bendix 3 3/8 disk brake calipers all around on my 51 COE.
I have 1.25 master cylinder bore mated to a hydroboost.
So, My question is what size brake lines do I run from the master cylinder to the distribution block, then from the distribution block to each caliper?
Chris
51chris #1174258 07/17/2016 4:21 AM
I'd probably run 3/16 to each front caliper and over the rear axle.
1/4" for between MC and proprotioning valve and to the rear axle.
Use an original modern truck with similar/same components as your guide, what did they use? May as well benefit from GM's engineering.
1952 Chevrolet 3800 pickup
---All pictures---
51chris #1174402 07/18/2016 2:52 AM
Grigg,
Thats my next step, trying to locate a modern with like parts
Chris
