| | | Forums66 Topics128,179 Posts1,057,134 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 117 | Hi all, I am getting ready to replace my rear motor mounts on my 1955 Chevy 2nd Series 3100 pick up with a 235 and 3 speed tranny. They are oil soaked mush and must go.
I'm ready to go, got the bolts broke lose, but am not sure where to lift the motor to get the clearance to remove the mounts. Last thing I want to do is break, bend, or crack a part. The engine and trans are still bolted together. The truck is up on jack stands supported at all for corners.
I've got a floor jack and a handy little bottle jack I can use. What would be the best way to raise the engine up and off of the rear cross member and rear mounts?
1955 Chevy Cameo 235 engine 3 speed transmission
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You should be able to get enough clearance by jacking the transmission. | | | | | Joined: Jun 2010 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 117 | Cool, thank you Cletis.
I'll grab some wood and my floor jack and push up on the tranny. I wasn't sure how strong the Trans Case is but sounds like she will hold.
Thank you very much for your advice. I'm going to tackle these motor mounts tomorrow morning...i'll let you know how it goes.
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Put your jack as near the front of the tranny as you can. If you have the lower dust cover on, be sure not to get the block of wood on it, it will bend as you go up if you do.
1959 3100 Apache Fleetside
| | | | | Joined: Jun 2010 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 117 | Ok good to know, thank you Cablesmill!
I took the cover off earlier today. I wanted to have a good look at the clutch and gave a good cleaning while I was at it.
I've got some 2x6's in the yard that i'll use. The plan is to spread them across the trans as best as i can and then to lift he motor at the tranny as close to the bell housing as i can get it.
It only have to lift about 3/4 to an inch as i eyeball it so i'm hoping to be ok. I plan on getting at this in the morning after my coffee.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can put all you want on that trans case. It is heavy cast iron. You wont break it. In fact it is safer to put the jack against the trans. instead of the wood block. The block can slip out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2010 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 117 | Thanks to everybody that replied. Got the job done...just lifted the motor from the trans as suggested. Worked like a champ.
Those mounts were a bear to get bolted back in...I had a hard time getting the bellhousing bolt holes to line up on the cross member with the new mounts...had to fiddle with it for a long while but eventually got it done.
I've been experiencing some shuddering/vibration when taking off in first gear and in reverse. I pulled the dust cover and had a look at the clutch and it looks dry and has plenty of meat. I'm hoping that was due to those rear mounts being mushroomed out and oil soaked.
I guess i'll know pretty soon!
