2 members (MickeyP, Charles in CA), 38 guests, and 9 robots.
Topics128,012
Posts1,055,311
Members48,419
#1173365 07/11/2016 6:55 PM
Is there a good way to drop my front end 2" with out buying a drop axle? For a 1954 1/2 ton. Just looking for a slight raked look.
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
Beast57 #1173402 07/11/2016 10:48 PM
I see they are for 3". I'm looking for 2". Would it be fine if I removed some leaf springs?
raise the back?
Beast57 #1173473 07/12/2016 12:44 PM
Eaton offers springs with a two inch drop.
http://www.eatonsprings.com/
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
Depending on your weight.........drops values are estimates.
Can be fine tuned with shackle length change.
What kind of loads will you be carrying?
I just have a 1/2 ton. I just want to lower the front and leave the rear stock. Has a 292 inline 6.
Removing the 2 shortest leafs dropped my front bumper about 1 1/2" and improved the ride a bit.
You Tube
Beast57 #1173558 07/13/2016 12:12 AM
Sounds good. Maybe I will do that
Just remember to take the caster angle into account when lowering the front only,as caster is lost it can cause a nervous/twitchy steering response.
It can be easily adjusted with shims.
More pix on Flickr.
Thanks for that important info! smile
