| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | Hey everyone, I just dragged home (literally) a '62 C40. I'm having trouble getting one of the rear brakes to un-seize. Dragging it across a few hundred yards of grass and gravel road didn't knock it free. I took the wheels off and have been beating on the drum and spraying WD-40 in every hole. Any other suggestions?
1953 1 ton panel
1953 1 ton panel
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Bigger hammer, they are never easy. I find a 3 pounder works fairly well. Beat, spray and pull hard. Good luck.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Make sure shoes are adjusted 'in.'
Ed
| | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | It seems that the breaks are a little different than the lighter duty stuff. Does anyone have a good picture of the shoe set up? I tried running back what I think is the adjuster but I think it may be rusted solid.
1953 1 ton panel
| | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | I got it apart. One of the adjusters broke loose and then I found my biggest hammer finally.
1953 1 ton panel
