8 members (68ironhead, 55shaker, Nhluvstruck, David Bush, MickeyP, TGP, Otto Skorzeny, treegrower),
59
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | I've got a '46 1/2 ton Panel that is almost ready for paint. The problem is I don't know how much to get. I've got the door jams and fire wall painted already. The formed panels on the sides and rear doors will be another color, thats only about 1 quart. Whats left is the body, doors,hood(inside and out), fenders and inner fenders. I'll be using single stage urethane paint and want three coats over all. I've been told 1 gal will do it, but the more I look at the truck the more I don't think thats right. I want to get all the paint at once to prevent it from not matching because the body, doors will be one day and the fenders and stuff will be another. Can somebody help me out with this??
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | I recently repainted my 1 ton panel. I was topcoating older paint and it took almost 3 quarts for the fenders and the longer than 1/2 ton running boards. The body, which is longer than yours, took about 2.5 gal of a single stage urethane and I really need another coat on the roof. This was just a backyard paint job so you might bear that in mind and the 1 ton IS alot bigger than the 1/2. I really think that 1 gal will be running pretty close to the wire, Don | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | I would say that if you are doing the whole inside you would be safe with 3 gallons. It would be better to have more than enough though as you can always throw an extra coat on without hurting the pocket book. A friend just painted a 65 impala and used omni brand paint at $80 gal. canadian funds. He used white and it turned out real nice | | |
