2 members (Otto Skorzeny, klhansen), 41 guests, and 9 robots.
Topics128,012
Posts1,055,315
Members48,419
#1172778 07/06/2016 7:07 PM
I need to make a tool for crimping an AD speedometer bezel. Any ideas are appreciated
Support lip of bezel on soft wood block and by hand lean on a screwdriver or punch to fold/crimp a few spots behind the case.
For a fancier tool might look at glaziers pliers, they're wide smooth jaws that are parallel when opened some, not closed. Some come with plastic jaw pads.
You could narrow one jaw to just as wide as the spots you want to crimp.
http://distributionsvimac.com/Catalogue.php?CAT=A05-A&LNG=1
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
I believe that's how I did it. Just rolled it with a screwdriver.
I just did this a couple days ago. The bezel is soft and bends easy. I used a pair of needle nose piers. One jaw on the front edge of the bezel (with a piece of plastic to protect the finish) and the second jaw on the edge of the bezel were I wanted to crimp. It did not take much pressure to bend/crimp the edge the bezel.
Dave from Northern Kentucky
My 54 3100
I used channel locks and mashed them over. I then realized that I may have roached my bezel. Turns out, that part of the bezel isn't visible once installed.
Carl
Big Bolt Forum Moderator
If you use channel locks, wrap the one jaw that will be against the front of the bezel with a few wraps of electrical tape. I did that when putting the upholstery clips on my seat and had to put a lot more pressure on than you will crimping your bezel. I did not mar the upholstery.
Mike
Moderated by  MNSmith
