5 members (DadsFirstPickup, 5 Window 9434, TUTS 59, Jon G, 1 invisible), 111 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
V
VEW
Offline
V Offline
I'm still working on my 41...trying to get parts cleaned up for reassembly.
When I disassembled the front, the splash pan (runs along the bottom, in front of the radiator) and the two side panels (again, in front of the radiator) were connected together.
I'm looking at them now, and it looks like they should be three separate pieces of sheet metal. Looks like they were "tacked" together.
Are they supposed to be three separate pieces? Would like to know before I take a grinder to them to make it right.
As always, thanks.
~ Victor
1957 3100 - moved on
I just finished assembling these parts on my 46' GMC. The parts you described are separate.
V
VEW
Offline
V Offline
Thanks for the reply Micksurfer. Much appreciated.
~ Victor
