1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I am not sure of the positioning of the inside door handle gaskets. Does the rubber one go behind the panel? Does the plastic one go between the handle and the panel? Does the rubber one get glued on? What keeps it from being worn by the operation of the metal that touches it? Inquiring minds need to know. Thanks - Scott
55 1st Chev.
| | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Rubber one behind panel, no glue..plastic one between handle and panel..Make sure to tighten handle firmly..You'll be fine, Steve | | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 |
55 1st Chev.
