4 members (chevyb, 1955 1 Series, Otto Skorzeny, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,076
Posts1,056,008
Members48,433
#1171765 06/29/2016 7:27 PM
Hello
have an inner fender gasket set, just looking for in put on assembly if this would be correct
2 2"x2"x 1/8 square gasket goes at fire wall between inner and bracket?
2 2" round gasket goes between inner fender and rad support?
2 3/4" x 14" gasket goes between baffle and inner fender?
2 3/4" goes between outer fender and inner fender across top of fender, would you still use this gasket if you are also using fender welt?
Thank you
I thought others would jump in to help you, guess not, so I will help as much as I can. I did the same on my 41 which is a bit different than the 46. I just matched everything up by bolt pattern and it went fine. The narrow one went between the outer fender and the inner fender at the bottom of the hood hinged piece. All of them seemed to match up with the pattern of the holes. My inner fender bolts up to a bracket on the frame instead of bolting up to the firewall like the 46. That will leave you with an extra piece you don't use. Let me know if you run into problems I will try to help you with pictures. I did not use welt at top of fender, only the gasket. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Thx Homer52 for your input I know it's a boring question
