7 members (TUTS 59, homer52, Otto Skorzeny, Youngin' Tut 59, dt235sd, 2 invisible), 122 guests, and 1 robot.
Topics128,052
Posts1,055,727
#1163894 05/05/2016 3:27 AM
I have a 54 GMC that I need to get a V-8 radiator for. I know the chevy is different but does anybody know if the mounting brackets are at an angle or are the straight up and down on a GMC? I had a guy send me a PDF of the drawing, the Chev brackets are at an angle. They can make it any way I want it but I need that piece of information before I order it.
thanks
n38139 #1163906 05/05/2016 5:18 AM
If I understand the question they are straight.
n38139 #1171057 06/25/2016 2:41 AM
Go to OldGMCtrucks.com
strickly GMC's over there.Im sure you would get an answer.
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
n38139 #1171063 06/25/2016 3:03 AM
Crusing in the Passing Lane
What is wrong with the original Radiator? I would try it out with the original first, 4lb. Cap, max, recovery tank, then see how that works.
Ed
