| | | Forums66 Topics128,051 Posts1,055,767 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | Just picked up a '55 rolling chassis, with 114in wheelbase and six lug axles. and am a bit puzzled by the lack of a model letter at the front of the vin. The vin is 255K0105xx. The vin of my '55 2nd is VH255LXXXXXX, V for V8, H for 3100 and 2 for second series. Shouldn't there be a D,H,M,J,or L at the front of the vin on my new chassis?
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The series designation wasn't stamped on the frame for some unknown reason. I guess someone thought the Year, Plant and Unit Number was enough to ID the truck chassis. Mike B  | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I've also seen an incomplete Vin on frames. They didn't need an "H", they knew it was a short bed. At the stamping point, maybe they didn't know what motor was going in it.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I've also seen an incomplete Vin on frames. They didn't need an "H", they knew it was a short bed. At the stamping point, maybe they didn't know what motor was going in it. Do you think that a GM factory put that "ID" on the frame, or do you think it was a dealer or the California DMV? | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | The Vin on the frame looks original, its on the frame just ahead of the steering box and also on frame, under cab area. One other different thing with this chassis is that the crossmember under the bellhousing area is a two piece affair, while the crossmsmber on my V8 truck is one piece. Difference between 6 and V8? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That is one of the differences between a manual transmission and a Hydra-matic.
That is the way the numbers were stamped from the factory. All the guesses as to why are guesses.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | More than likely the unit number was stamped on the frame early in the assembly process, then later down the line the cab ID plate would use that unit number and add the engine "V" or no "V" and the model designation (strickly talking TF trucks). Chevrolet started stamping the frames 1955 Second Series, left rail under the hood and under the cab. Mike B  | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have deduced, from previous posts, that the practice started in 1955 but wasn't done at all plants until 1956. I have also deduced it wasn't done to GMCs, even though some GMCs were produced at Chevy plants. I haven't determined if GMCs and Chevies came down the same assembly line. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | GM didn't specify it anyplace Tim, but as Cletis sez it's been established here the Chevy frame vin stamping started with the 55.2 trucks onward, never seen a TF truck without it ... also, I believe the number was only stamped on the top rail by the steering box until the early 60's, when they started putting it further back, under the cab
Bill | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I believe the number was only stamped on the top rail by the steering box until the early 60's, when they started putting it further back, under the cab
Bill Frames were stamped in both places from the begining. I've striped lots of '56/57 trucks and I have a 10500 and 4400 bare frame here now, they all had/have two stampings. Mike B  | | |
