7 members (fonz8261, jmoore, Hotrod Lincoln, Woodcmiami, Ludwig.van.dille, Shaffer's1950, 1 invisible), 73 guests, and 1 robot.
Topics128,077
Posts1,056,280
Members48,441
Hello, I just purchase a 1953 GMC 9314 canadian model and I would like to know what type of engine I have in it.
this is the serial for the engine
c661009
thanks
Leo Offline
Moderator
Moderator
Welcome to the stovebolt site. Without using the serial number (casting number would help more) I would suggest that you have a 235 Chevy engine in your truck. Canadian built light GMCs used Chevrolet engines. In addition, I have heard that the Canadian trucks had the full pressure engines in 1953 while in the US they came in 1954. You could try asking in the driveline forum.
Leo
One fast way of determining if it is a low-pressure block is to look for the low-pressure-block's oil distributor "plate" on the left side of the block (obscured by the exhaust pipe).
Thanks, I'll look on the side of the engine.
I did look just behind distibutor and the number is C661009???
just look again for more number and just in front of the fuel pump it is gm 5848850 and the manifold is 3701887 can some help me please
