3 members (Shaffer's1950, Wally / Montana, 1 invisible), 46 guests, and 1 robot.
Topics128,090
Posts1,056,022
Members48,430
#1170475 06/20/2016 9:48 PM
On a 56 (3200) where does the heater control valve (ranco valve) mount? I drew a pict. of where the hoses go but not the valve location. I took it off(4 years ago),can not figure it out. A picture would be great.Any help is appreciated.
assuming you're working with a deluxe heater, the valve mounts to a metal tab on the core mount [actual valve missing in that pic] - all 55.2-59 deluxe heaters are the same .... if you don't have a deluxe model, there was no Ranco valve
the heater core box has HD-02B-56.It looks just like the pict.that says 57 standard. It is a ranco valve. It is a std. heater
that 57 standard heater [round core] didn't come with a Ranco valve, none of the standard heaters did AFAIK, if yours had one, someone added it ... all the 57 standard [recirculating] heater had for controls was the fan switch - see accessory install manual here
Ok thanks for the info. I must have picked up the valve somewhere. That explains why there is no opening for the valve.
