2 members (Otto Skorzeny, DennisM), 91 guests, and 5 robots.
Topics128,026
Posts1,055,403
Members48,422
#1169806 06/17/2016 1:25 AM
Hi, I have a leaky oil plug, what could be wrong. Would it be the plug, threads, gasket or something else? This plug did not have a gasket on it.
It is a rebuilt engine with expensive break-in oil leaking all over my floor.
Stove #1169808 06/17/2016 1:36 AM
Put one of those white plastic "gaskets" on it and see what happens. Save the oil first in a clean container and put it back in.
Stove #1169814 06/17/2016 1:58 AM
I agree with Wally you should have fiber/crush/nylon gasket on the plug. There are slight oversized plugs available in the event that this one is too loose. Just collect your expensive oil and sort it out.
Lots more pictures
Stove #1169904 06/17/2016 4:31 PM
Thanks, I put in the correct plug but it's still leaking. It feels quite sloppy in the threads, I wonder if the oil pan threads are tapped correctly? Perhaps the next thing is the oversize plug, it looks like it cuts it's own thread.
This engine is rebuilt, I think they should have got the oil plug right.
Stove #1169909 06/17/2016 6:23 PM
Riding in the Passing Lane
If the plug will not tighten down with a gasket, get an oversize drain plug. Yes they tape new threads.
1972 Chevy c10 Cheyenne Super
Stove #1169915 06/17/2016 7:52 PM
The plug gets tight but it still drips.
Stove #1169918 06/17/2016 7:58 PM
If you have a new plug with a new washer and it sill leaks, you may have a crack in the oil pan.
Stove #1170102 06/18/2016 1:56 PM
The pan was probably damaged during transport of the engine. I can't win for trying.
I'll remove the pan and have it welded.
Stove #1170105 06/18/2016 2:14 PM
Try the oversize plug first.
Lots more pictures
