4 members (ronsway, Wally / Montana, 2 invisible), 148 guests, and 6 robots.
Topics128,078
Posts1,056,052
Members48,433
I recently replaced my original instrument cluster, as none of the gauges worked, with one i bought from classic Industries. After installing a new wiring harness(for the whole truck) we hooked up the cluster and the speedometer reads about 30 mph's faster than the correct speed. Any suggestion how i can calibrate this or at least get it closer to correct speed?
The Truck has a 350 small block with an automatic transmission that replaced the original 6 and 3 speed (this was done before i bought the truck).
Bobby
1958 Chevy 3100 Project
the problem is the speedo drive in the trans, you need to find a different speedo gear for it or use something like a GPS to figure out the accuracy and live with it .... if it's a "steady" 30 fast at all speeds you might move the needle down
Have you checked to see if the odometer is as far off as your speedometer? Mine doesn't register speed nor miles accurately, and by different percentages.
boy, that would drive me crazy if I was using a mile marker for a check and did not know my odometer was off.. I dont have nor know how to use a gps.. I am falling behind in my old yrs.. sometimes I do check how fast cars are going in my block by a mental time/count
and using certain aids. I have previous timed them with my count and speedometer, clever, huh. This would be when I am out side watching them go back.. it is a 25 mph zone and most dont even come close to it..wife thinks I am crazy when I point one out and tell her..
Redryder pix
My Hotrod
back yard wrench turner
I have a speedometer app on my phone. I used it to determine my speedometer was reading 10 mph slow. I moved the needle and it's very close now.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
DLBrooks
DLBrooks
If the speedometer is in working order, I was told it needs to spin 1000 rpm for 60 mph. I am not sure what trans you have probably a 350 turbo or 700r4 you need the gearing to match your rear gears and tire diameter. There are calculators on the web. You may need only a diff speedo gear but it could be a housing and gear as Flxible said above.
http://www.tciauto.com/tc/speedometer-gear-calculator/
As Carl and Wayne said above --check actual speed with a garmin, tomtom or a phone app for a sanity check.
I would guess you are now running a 4.10 gear and the trans was set up for a 2.73, 3.08, or 3.42 or so. If I am thinking correctly.
1959 GMC 100 Fleet
Follow in the DITY
Using the odometer to calculate the is the easiest way to determine where the problem. The odometer is gear drive and the speedo is magnetic drive.
If the problem is the trans drive gear (most possible) the error will be a ratio.
Drive some miles 10 is best, 2 is about minimum, checking the mile markers. Then compute the error. Lets sau it's 10% low, then when the steedometer is reading 20mph you will be going 22, 60 indicated will be 66 actual. Change the gear accordingly or add a ratio adapter. Moving the needle can't help this.
If the mileage check is a perfect 1:1 then move the needle.
Moderated by  ndkid275, Phak1
