7 members (JW51, J Lucas, papas52, Hotrod Lincoln, Gdads51, DadsFirstPickup, 1 invisible),
104
Mod | | | Forums66 Topics128,162 Posts1,056,953 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 4 New Guy | | New Guy Joined: Jun 2016 Posts: 4 | I recently acquired a 1939 Panel Truck (in pieces!). Does anyone have photos of the rear mounting brackets, etc. to mount the body to the frame or any idea where I might find/purchase a body assembly manual? Thanks in advance for any assistance. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | GTO,
Welcome to Stovebolt.com.
I doubt you will get a response from someone with an assembly manual, but, that is a good question.
You have a somewhat rare truck - check out the "Gallery" (it is listed in the menu at the top of this page). If you find a member with a truck like yours, contact them in a Private Message or an email message. However, you will not be able to contact anyone until you have made 4 more approved posts (your first post has been approved).
Submit a few posts telling us about your truck, or about what you need/want to do to your truck, or other questions/comments.
FYI: You posted two similar posts. One was deleted.
| | | | | Joined: Jun 2016 Posts: 4 New Guy | | New Guy Joined: Jun 2016 Posts: 4 | Thanks for the info. I'm having a difficult time finding much information on the '39 at all, but your idea is a good place to start. | | | | | Joined: Jul 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 34 | Hi GTO, Try contacting GMHeritagecenter.com. They have helped me in the past. They may even be able to give you the history of your burb if you supply them your vin number. https://www.gmheritagecenter.comRuss Sweet | | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | GTO,
Send me a personal email--I just completed a 1938 3/4 ton panel, all original.
JM | | | | | Joined: Apr 2006 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 62 | GTO, I have a 1939 Suburban and can tell you the rear mounting block is 2 3/4" wide x 3 3/4" long x 1 3/4" high. I made mine out of oak, copied the old original block. The bolt goes thru the hole in the rearmost chassis crossbar. e-mail me for photos. [email protected] | | |
