| | | Forums66 Topics128,049 Posts1,055,653 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | has anyone used the HF flanging/hole punch tool. Does it make good straight lines on long pieces. | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Is it the air flange tool. If so I have not used mine much but it is a hand tool and would be as good as the hand the tool is in.should be okay if you took your time and had a nice cut on the metal to go by. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | It is not ideal for longer than 6 inches or so. You can make it work, but the kind that has a crank on it and rolls the flange is better. I butt weld everything so have not used my air flange tool in a long time. | | |
