3 members (Phak1, Otto Skorzeny, TexasA&M48Truck), 110 guests, and 1 robot.
Topics128,092
Posts1,056,040
Members48,433
#1168825 06/10/2016 12:28 PM
Just bought a new fan for my 55 series ll pick up.
Original fan was damaged and although I straightened it, it looked a bit wobbly when idling. It just didn't run true.
New fan is 2" smaller in diameter than the original one. Seller says that's the only fan they sell and there have never been any problems.
Should I try to find one with the original diameter or will the 14" diameter work OK?
Many Thanks
sepp #1168829 06/10/2016 12:36 PM
I'd try to find the correct size fan blades, or one closer to the original 20" diameter.
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0171.htm
' Offline
Sepp,
According to the GM parts manual.
A 1955 & 1956 - 2nd. Series uses a 20 inch,
4 blade fan - GM part # 3716797
A brand new GM NOS 20" fan with 4 blades
is available from:
1.) Dan's GM Obsolete Parts
Chinook, Montana , USA
phone: 406-357-2615
Dan's has ( 1 ) - GM # 3716797) in stock.
2.) Chicago Auto Parts
Saint Anne, ILL. USA
phone: 815-614-3122
Chicago has ( 1 ) - GM # 3716797 in stock.
email address:
[email protected]
I've purchased NOS parts from both of the above.
Alway's great parts.
You can also try: Bruce Bugay in Virginia.
He buys & sells GM NOS parts.
phone: 1-804-752-6036
email: [email protected]
Bruce is retired from General Motors.
I've purchased many NOS parts from Bruce.
Always great parts.
Hope this info helps you out.
George '54 3600
1954 3600
Now cruising in
The Passing Lane
sepp #1168953 06/11/2016 6:21 AM
PM sent
1959 3100 Apache Fleetside
sepp #1168968 06/11/2016 2:14 PM
"there have never been any problems"
Your truck overheats = he has no problems.
A 14" fan in a 20" shroud means the shroud stops working.
A 20" fan flows more than twice as much CFM as a 14" fan (all other factors same).
sepp #1169863 06/17/2016 8:56 AM
' Offline
GM - 4-blade Fan - GM # 3716797
SUPERSEDED: to GM # 3739015 on ( 3 - 1 - 1958 )
photo@photobucket
http://i669.photobucket.com/albums/...NOS/GM_%203739015_%20NOS_zpsfyrjogdz.jpg
There is a GM NOS Four Blade 20 " Fan - GM # 3739015 on ebay right now
for $59.00 or make an offer
Go to ebay & in the search box type - 3739015
link: http://r.ebay.com/OW8uC7
Dan's Obsolete & Chicago Auto Parts - both have
( 1 ) GM NOS Fan # 3739015 in stock
George '54 3600
1954 3600
Now cruising in
The Passing Lane
sepp #1170075 06/18/2016 7:52 AM
You should put the proper size fan on the truck.
