| | | Forums66 Topics128,188 Posts1,057,334 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 46 | Has any used the Chevy Colorado rearend under an advance design truck. I currently have a ten bolt under my truck that needs a total rebuild and thought this would be a good option. I would want to run a 5 on 4 3/4 bolt pattern and I believe the Colorado rear ends are 6 bolt. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | IIRC from when I measured on in the shop, they come out to right at 63", give or take. They do have a 6x5.5 bolt pattern. You might want to consider the 10 bolt from a 4x4 S10 with the ZR2 package, '98-'04. Those are basically a narrowed version of the full size truck 10 bolt, only with the 5x4.75 bolt pattern. They also have factory rear disk brakes, and usually a factory gov-lok system.
Bill Burmeister | | |
