| | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | I'm putting together the transmission out of my 1946 Chevrolet 3/4 ton truck. I'm replacing the front universal joint. Is there a spacer that goes between the universal joint and the rear transmission bearing? The reason I'm asking is because someone rigged the original if it even is original by pressing the speedo gear half way on and then brazing a small spacer inside the speedo gear so the universal joint will fit flush with the output shaft so the bolt that holds the universal joint on can be tightened. | | |
