1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 20 New Guy | | New Guy Joined: Sep 2012 Posts: 20 | I was curious if I could get the 48 to run so the last couple weeks I changed the fuel pump, plugs, points, condenser, cap & rotor. At first I had a problem not getting spark and getting the points gapped right & got that all figured out. After some tries and one battery charge later I got it to where it really runs well for sitting in a field for who knows how long. Big thanks to the stovebolt site because all the answers to my problems I ran into I discovered by searching on here. My next problem I need to solve is my back brakes are froze up. Any suggestions as to how to free them? Thanks again, Jeremy http://s962.photobucket.com/user/jf...0602_204217_zpsu42omktg.mp4.html?filters[user]=138622147&filters[recent]=1&sort=1&o=0 jeremy 1947 Chevy 1st series 1/2 ton
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Adjust them in(looser) so you can get the drums off.
Ed
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Whatever you do, be careful not to damage the drums. They don't make them new and replacements are very hard to find. I would try moving each wheel both forwards and backwards. Sometimes when the brakes are adjusted up, the rust forming on the inside of the drum causes them to completely bind. | | | | | Joined: Sep 2012 Posts: 20 New Guy | | New Guy Joined: Sep 2012 Posts: 20 | Ok thanks for the info. I was reading on the h.a.m.b that a couple of guys used water inside the drum to break it free. Anyone heard of doing that?
Thank you jeremy 1947 Chevy 1st series 1/2 ton
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Be very careful to work the adjusters back and forth to free them up. They have little nubs that engage the bigger cap on the wheel cylinder piston to get it to turn. If you mushroom them flat then you can't back off the brake shoes.
When you get it all apart use lots of Never Seize on the parts so they won't freez up again. I even use it on the pistons in the wheel cylinders which keeps the aluminum pistons from seizing to the iron cylinder. Be careful not to get any on the shoes. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
