0 members (),
138
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 79 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 79 | We just finished a rebuild of a chevy 235, but I want to keep the original look of the motor. Does anybody know if there is a 'bridge' available or any hints on the installation. Langdon's Stovebolt sells a bridge for $25, but then they want $80 for an adapter kit -
Any help would be immensely appreciated, folks!
Lisa
Lisa
1952 Chevy Carryall in completely original condition Pulled out of a barn in Colorado high desert
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Isn't that just two special studs (that are from a 216) that go on two of the rocker hold-downs with an acorn nut on top of each? What else is involved? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Deve is correct. You just need the two studs and valve cover from the 216.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Isn't that just two special studs (that are from a 216) that go on two of the rocker hold-downs with an acorn nut on top of each? What else is involved? Here is what is needed. Stud kit
Fred 52 3600 69 C-10
Lisa
