1 members (baldeagle), 35 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#116688 06/30/2005 9:37 AM
I remember my Dad using a citrus based cleaner sold by NAPA to remove undercoating. It worked great. But as soon as it hit rubber it would insantaneously turn to goo. I've contacted Napa and they look at me like I'm crazy and my Dad doesn't remember the part #. Anyone here, by chance, happen to know what the heck I'm talking about? :confused:
thanks,
shawn
#116689 06/30/2005 12:52 PM
No, but...
I use EasyOff oven cleaner to remove it with success. I have a friend that says he had success using some sort of heat gun (??) to soften and scrape it off.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
#116690 06/30/2005 5:41 PM
Heat gun - hair dryer that's been using steroids. Great tool for many things, I use mine to do heat-shrink tubing on wiring all the time. I think I paid $12 for it at Harbor Freight.
1954 GMC De Luxe COE
#116691 06/30/2005 5:42 PM
Hi Jerry,
How long did you leave the easy off on?
I know this is unrelated, but how are the carter/webbers working? I'm firing mine up for the first time today.
Have a good one,
Shawn
#116692 07/01/2005 12:52 AM
I left it on until everything got soft under it.
The CW carbs are fine now that I figured out the choke. Everything is apart again. The intake started to leak so I took it off. The headers went to JetHot Coatings and I'm detailing everything under the hood. Someday I'll enjoy this thing.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
#116693 07/01/2005 3:09 AM
Junior Member
Junior Member
Get yourself a Fein MultiMaster. It will be the best tool you will ever buy. Not only will it remove undercoating like butter, it will cut sheet metal, composites and wood, remove stubborn gaskets, detail sand, and rasp, all without rotating or reciprocating blades. No handyman should be without one. Fein is listed in the vendor section under tools.
42 11/2 ton 4x4 military Chevy
54 JD 40 crawler
58 JD 420 crawler
http://community.webshots.com/user/eal4x4
