| | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 22 New Guy | | New Guy Joined: Apr 2016 Posts: 22 | Where can I find patch panel for back bottom of rear fender. | | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | I could have sworn I saw them in one of the catalogs I have. Or maybe it was online. But I sure can't find them now. Wherever it was, I recall them going for $100. I made my own patch panel. See here: https://www.stovebolt.com/ubbthread...der_Patch_panel_forming.html#Post1146321
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | Tim,
I believe he was looking for a rear fender rear patch panel. The ones you linked are for the front of the rear fenders. They do work well, though. I was looking at a Brother's Truck catalog and originally mistook a front fender rear patch for what he was describing (a rear rear patch panel). When I posted I searched about everywhere I could think of, but wasn't able to find them.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, Kevin
Sorry, old norse | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Jim carter shows them on back order. Jim carter SMF400L and SMF400R are the part numbers.
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | Jim carter shows them on back order. Jim carter SMF400L and SMF400R are the part numbers. Again, those patch panels are for the front of the rear fenders. Old Norse was looking for patches for the REAR of the rear fenders. I don't think anyone makes them (except me  , but I only make them one at a time and don't sell them.) If anyone is looking for those front patch panels, I can say that the ones from JC are good quality, having just used a pair of them.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Depending on how much of it you need, maybe you can find a contour that would work in the back using those? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Contact Ray Stanley at [email protected](413) 477-6467 He'll take care of you. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | Depending on how much of it you need, maybe you can find a contour that would work in the back using those? I don't think the front patches would be much use on the rear. The rear of the fender is a compound curve (dished) in most areas that rust out, and the front patch is basically a flat curve (single direction) with a flange. The main part of the rear rust-out isn't hard to form with a hammer and sandbag, but some shrinking is needed to get the compound curve formed. I was able to form patches for the rear of both my rear fenders using stump shrinking on my first attempt.
