2 members (Wally / Montana, TooMany2count), 32 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#1164287 05/07/2016 8:13 PM
I just installed pertronix on my 53,if I read the search right, the plugs should be gaped 40 to 60, which is the best. Also it said to retime the dist. So how far in advance should I go? All I have on the fly wheel is a dot, I have heard, I should go about 1/2 inch before TCD any input will help. 53 3100 235 root
root #1164298 05/07/2016 9:12 PM
I retimed using vacuum gauge timing technique (maximum vacuum at idle).
From Pertronix:
What should I gap the spark plugs to?
The Ignitor has no set specification in which the spark plugs should be gapped at. Every engine responds differently to spark plug setting. In most cases increasing the factory recommended gap by .005 improves the engine performance.
.033-.038 (0.035) was original 1953 235 gap-spec (AC 44-5 Commercial plug)
root #1164337 05/08/2016 2:50 AM
I gap the plugs on my 248 with Pertronix at .045. I also use the vacuum timing technique. It sets it at about 10° btdc.
root #1164413 05/08/2016 7:43 PM
Thanks for the input, now I have a place to start. root
