| | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 23 Junior Member | | Junior Member Joined: Mar 2004 Posts: 23 | I have most of the paint stipped off with a 60 or 80 grit pad. I am going to treat the metal with something like Ospho, Next to use a filler for any dents. Then to apply a primer - surfacer, is it ok to spray on at 80 grit? or should it be smoothed out further at this point?
How am I doing so far? | | | | | Joined: May 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 50 | Primer will definately cover 80 grit sanding scratches. Sounds good so far. Later
Dave
Even a blind squirrel gets a nut sometimes!
