1 members (WICruiser),
164
0
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 6 Member | | Member Joined: Dec 2001 Posts: 6 | Has anyone used the Miracle Paint product sold by Bill Hirsch Automotive. It sounds almost identical to Por-15, which I am no longer considering for my resto project because of the isocyanates. I emailed Hirsch about it and they responded saying they didn't see anything in the MSDS about isocyanates. Does anyone know anything about Miracle Paint or where to look for more info? | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Can't say for sure about isocyanates, I would probably say it does, because it and POR 15, read about word for word on use and thinning. Are you figuring on spray it? If your going to paint it with a brush it's not as big a problem. Just make sure you have plenty of ventilation, maybe use a fan to carry off fumes if your doing large areas.  | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I have used the Hirsch paint in the past on frames. Seems to be a fine product , equal to the other rust kill paints. It says on the can that it contains Diphenylmethane, Toluol carbon. Says to use an organic respirator when spraying.Sorry, I dont have the MSDS sheet here. | | |
