2 members (Thomaslb, Eddie54),
166
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 46 | I am looking for a pleated style seat kit for my 1951 3100 truck. I will also need to replace or move springs to stiffen the drivers side seat bottom. Has anyone been successful in this process or others to stiffen the bottom seat.
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I removed all the springs from the bottom on my 58 and am going to use foam. The problem with the old springs is, they get weak where the driver's butt sits. You replace the ones under the driver with new ones, now they are poking you in the butt and the ones next to them are not as strong or hi so, you end up replacing all or most of them. Some guys have been able to put a piece of carpet over the springs to stiffen it up and even it out but, I have not tried that myself. I may try that on my 55 just for kicks for moving it around the yard (easier on the butt than a 5 gallon bucket!). I went with foam in my 59 Suburban and have been using it as a daily driver for the last 15-16 years. | | |
