3 members (BC59, Brian Moore, rfs56trk), 161 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
#1162657 04/28/2016 1:58 AM
I am looking for a pleated style seat kit for my 1951 3100 truck. I will also need to replace or move springs to stiffen the drivers side seat bottom. Has anyone been successful in this process or others to stiffen the bottom seat.
Big Bolt Forum Moderator
I removed all the springs from the bottom on my 58 and am going to use foam. The problem with the old springs is, they get weak where the driver's butt sits. You replace the ones under the driver with new ones, now they are poking you in the butt and the ones next to them are not as strong or hi so, you end up replacing all or most of them. Some guys have been able to put a piece of carpet over the springs to stiffen it up and even it out but, I have not tried that myself. I may try that on my 55 just for kicks for moving it around the yard (easier on the butt than a 5 gallon bucket!). I went with foam in my 59 Suburban and have been using it as a daily driver for the last 15-16 years.
Mike
Moderated by  ndkid275, Phak1
