| | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 61 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 61 | Found a windshield frame at Spring Carlisle. Looks at first glance to be a '41-'46 pickup, but the frame is 1.5 inches wider, 3/4 inch taller- and has a wider divider bar that is not stainless. The attachment at the bottom for the crank out is the same, the hinges at the top are not. Any ideas? Thanks. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | A picture would help with identification. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I've only seen two different size cabs for the 41-47 body style. Only one style for Chevrolets, & the second style was on the larger Heavy Duty GMC Trucks. The heavy duty 41-actually 49 Art Deco trucks I've seen, had a dual split windshield with two cranks. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | My best guess it is not a Chevy at all was miss marked.
Marv. | | |
