0 members (),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | I finally got a couple of the 20 inch 6 bolt lock ring rims needle scaled, painted and put back together with new tubes and a decent tires and aired up to around 30 psi. Everything has gone well so far but I saw the radial tire was labeled for a 85-90 psi and though I would ask the group before filling them beyond 40 psi.
I thought I had read somewhere, maybe an OSHA brochure not to fill these rims beyond 40psi.
What is the correct tire pressure?
Thanks Dan | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | When I bought 6 new tires for the 48 2 ton I had the dealer mount them on the wheels I had cleaned and painted. He said not to go over 75 lbs. Tires are rated to 120 lbs.
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Under-inflation is about as bad as too much pressure. If the wheels are in good condition and lock together properly, more pressure just makes them lock more firmly. If they are in danger of separating because of wear and/or improper fit, they shouldn't be inflated at all.
Keeping the pressure low will actually increase the risk of a wheel coming apart from rubbing a curb or hitting certain kinds of bumps since the locking system relies on adequate tire pressure keeping the pieces from being dislodged from each other.
Obviously, RH-5 widowmakers don't need to be inflated at all- - -that tiny locking lip is just too susceptible to minor damage, wear, or rust causing an explosive separation. Jerry
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If the tire is labeled 85 to 90 psi, that is what you need to run. Less than that will cause the sidewalls to flex, generate heat and ruin the tire. | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | Thanks for the input, I need one more rim and I can retire the widow makers. The guy at the tire shop said they make great grills or fire rings.  | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The pressure marked on the tire is amount needed to get the maximum load bearing, not the normal operating pressure. The tires on your pickup may say they are rated for 1874 lbs of load at 45 lbs pressure, but the recommended operating pressure is 30 lbs. | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | The pressure marked on the tire is amount needed to get the maximum load bearing, not the normal operating pressure. The tires on your pickup may say they are rated for 1874 lbs of load at 45 lbs pressure, but the recommended operating pressure is 30 lbs. Are you sure about the 30 psi? I remember inflating my pickup and car tires to 30-32 psi and it was rated on the tire. GMC recommends tire inflation on my 2008 2500HD Duramax pickup at 60 front and 70 rear and the tires are rated at 75 psi. Once again it is rated on the tire. I am changing the rims over to 20 inch 6 bolt stud centered Budd rims with lock rings and agree that operating with under-inflated tires can lead to premature tire failure.
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I agree with Jim Sears. Tire pressure is a function of load. In sports car circles they say that tires should gain about 3 psi after running a few miles.
My rig carries 6,000 lbs on the rear and 3500 lbs. on the front. If I inflate the E-rated front tires to 80psi listed on the sidewall, it rides rough and handles miserably. I run 36 ft. and 70 rr. when loaded.
Last weekend I drove it pulling a utility trailer 250 miles, left the trailer and came back empty. I was too lazy to drop the pressure on the rears and suffered from poor lateral stability. The saving grace was the trailer acting as "drouge" and keeping things going straight. Coming back empty it was a lot more work to drive. I almost stopped to drop the tire pressure to about 36 on the rear but then the road improved and I just suffered with it till I got home. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jul 2014 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 48 | 1Ton_Tommy is 100% spot on. Too many tire guys don't have a clue. I run my pickup (don't scold me for driving an F250) at 70 front, 45 rear unless I load it. When I get an oil change I always have to let 10 out of the front and 35 out of the rear because they go to max inflation, which makes it ride like I'm bouncing on basketballs. All 4 of my tires are almost worn out and they are worn evenly across the tread.
Most tire blow-outs you see are from underinflated tires - severely underinflated, not within recommended guidelines. Note how your tires say "MAX" inflation pressure? There is a minimum as well. | | | | | Joined: Aug 2001 Posts: 3,596 Moderator | | Moderator Joined: Aug 2001 Posts: 3,596 | On my old F-250, with the 7.3 power stroke. When empty, I run 65 in the front and 50/55 in the rear, but also carry a 30 foot, 3/4 inch chain in the very back to smooth out the rear some. Probably about 300#. When loaded, fronts 75 and rear 70+ depending on the load. Tires are rated max. pressure at 80 psi.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | Thanks for the input. When I get it on the road I'll set them at 35psi and take it form there. I don't need a bouncy ride since this model does not have shocks. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | You need to re-read Hotrod Lincoln and Crenwelge posts on page 1, you have split rims, not one piece tubeless...BIG DIFFERENCE! Be safe, Mike B  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You need to re-read Hotrod Lincoln and Crenwelge posts... Yep, don't skimp on the air pressure. For truck tires I usually start out at the recommended pressure on the sidewall and if lightly loaded and as needed for comfort reduce the pressure a little. Keeping an eye on how they look and wear and keep enough air in them so they always look tall and proud and never wear the outside of the tread first. Grigg | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | The old rule of thumb we used for tube type tires on multi-piece rims was if the pressure of a tire was more than 10% below the recommended pressure, we did not attempt to air them up- - - -break it down and find the leak! Attempting to add air to a low tire could possibly cause an explosive rim separation. My employees knew that was a good way to get fired. Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | [quote=Jim Sears]The pressure marked on the tire is amount needed to get the maximum load bearing, not the normal operating pressure. The tires on your pickup may say they are rated for 1874 lbs of load at 45 lbs pressure, but the recommended operating pressure is 30 lbs.
Are you sure about the 30 psi? I remember inflating my pickup and car tires to 30-32 psi and it was rated on the tire. GMC recommends tire inflation on my 2008 2500HD Duramax pickup at 60 front and 70 rear and the tires are rated at 75 psi. Once again it is rated on the tire. Jim isn't really meaning any specific truck, only using those numbers as an example. However, there are real world example that have cold inflation pressure for a given tire size/load rating installed on the vehicle that are not the same as the maximum pressure listed on the sidewall. Example, '98 Chevrolet K1500 with a 245/75/16 LT E lead range. The tire is marked for 80 psi max, however, the vehicle spec is 45 psi cold. Same year, make, model truck with the P rated option tire, which is rated anywhere between 35 to 41 psi depending on brand, runs 35 psi. Obviously, using different size or load rating tires will change what pressure should be run. Admittedly, there are times that the "engineers" get it wrong, and specify a pressure that is too low. remember the Ford Explorer? On the not inflating over 40 psi part, that's for seating the tire. Once seated, it can be set to whatever the cold pressure for the tire should be.
Bill Burmeister | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Does everybody need to be reminded of the original question- - - -"TIRE PRESSURE FOR SPLIT RIMS"? My concern is that someone who does not understand the physics of how a split rim holds itself locked together will reduce the pressure to a dangerous level and hurt himself or someone else. If he chooses to do so after the danger of reduced pressure has been explained, Forrest Gump's Mama had a saying about that person! (and it wasn't "Life is like a box of chocolates") Jerry
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Bill, That brought back alot of Memories...Roadway Express At the height of that Mess We had a 28ft. pup Spotted at every Firestone dealer on Long Island Just to Cart the takeoffs away,GOOD or BAD. Fill it up,spot another. Many trailer loads back to Firestone,MUCH overtime. steve sr. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Jerry, You are So Right and Your rule of thumb is the correct and SAFEST Way to be. Err on the side of Caution. Improper Servicing techniques/procedures is what usually gets Most so called techs Maimed OR Worse. regards always, steve sr. | | |
