| | | Forums66 Topics128,131 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 26 | I want to stay as stock as possible. I have aquired a 12volt generator/power steering pump unit all in one Delco Remi. What gear box is best for this modification. Plus what steering gear. | | | | | Joined: Mar 2015 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 26 | Is there a rack and pinion power stering unit without going Mustang 2. Keeping as stock look as possible using the original front axle. I am going to go disc fronts. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Rb55, Check out Western Chassis. They have a rack and pinion that bolts onto a 47-55 straight axle. Not sure how they do it, but it's there and it costs $699.00. wessternchassisinc.com Also, CPP has power steering kits if you don't want rack and pinion. Classic perform.com | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I would very leary of any rack and pinion setup that mounts to a solid axle. Those setups are Mickey Mouse at best, and add significant weight to the axle.
Bill Burmeister | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | That's what I've heard too. Not sure how they've done it, but they sell a kit for it. | | |
