3 members (Samantha, DoubleB, Hugh63c10), 321 guests, and 4 robots.
Topics128,088
Posts1,056,124
Members48,435
I have just purchased what I believe is a pre 1955 civilian 302 GMC engine. (At least that is what I think it is). I do not have it home yet to get numbers off it, but this I know, it does not have side motor mounts and it does have the right side front of engine mechanical fuel pump. I am sure that the engine was set up to run on 12 volts, at one time, as it has a late model GM 6 cylinder HEI unit installed, but I do not have the starter, water pump, carb. and alternator. My question, Will any 6 volt GMC starter, 228, 248, 270 and 302 interchange. I suppose I will stay with 12 volt and run it against a 6 volt starter (if I have the 6 volt flywheel). I am not sure what flywheel I have yet, but hope to know shortly. Any help is appreciated.
smile Alan
1947 (early) GMC EC-302 Dump Truck
Jimmy
More pix in Photobucket
3B Offline
Hy Big Als, as far as I know the starters suitable for the six volt flywheels interchange and the starters suitable for twelve volt flywheels also interchange, hope that helps.
3B Offline
Hello 3B......yup that is what I was thinking. Next question, do the Chevrolet and GMC starters, of the same vintage, interchange?
smile Alan
Jimmy
3B Offline
Hy Big Als, I have swapped six volt solenoid starters from cars onto the truck engines when checking engines for their internal conditions, compression checks, vacuum gauge checks that sort of thing. I have also done the same type of thing with the later twelve volt solenoid starters from the truck engines for use on the engine test stand, hope that helps.
