10 members (jupitor, treegrower, Lightholder's Dad, GMCJammer51, J Lucas, JW51, Tinker5, TUTS 59, wilbur53, 3B), 216 guests, and 1 robot.
Topics128,080
Posts1,055,952
Members48,430
#1161567 04/21/2016 2:47 PM
I can't find a diagram of how the heater is hooked up. All I know is that the hot water flows through it no mater what and it makes the cab very hot. Does it have its own thermostat?
Andy
Sometimes you're the window
Sometimes you're the bug
No, you need to add a Summer/Winter cut-off valve in one of the lines under the hood. The heaters were all dealer installed accessories so there really is no right or wrong way to do it. That said Chevrolet did have a valve-nipple that would thread into the block that the hose connected to that made it an easy job.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Since I won't be using it in cooler times can I just disconnect it?
Big Bolt Forum Moderator
you can disconnect it without hurting anything, you just won't have heat (or defrosters)
Mike
