| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 17 Junior Member | | Junior Member Joined: Sep 2004 Posts: 17 | i just purchased a 48 chevy 5 window 1/2 ton truck.i see things that look like this could be a 49,how can i tell for sure? | | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | There are probably more differences, but the biggest I know is gas tank location. If it is in the cab, it's a 49. In the bed, it's a 48.
I suspect we will hear more from others.
Have fun!!! | | | | | Joined: Sep 2004 Posts: 17 Junior Member | | Junior Member Joined: Sep 2004 Posts: 17 | the tank is in the cab,but the door windlace has the metal strips screwed down and the screwed in headliner center bow.those are supposed to be on a 48 only.could this be a late 48?i dont know much about these yet. | | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Hey 48 Chevy, Both of my 48's have the tank under the bed. The serial number should have the Letter F in the code. FP for the half ton and FR for the 3/4 ton. Ralph | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | 48, do you have the "VIN" plate on the driver's door? What is the serial number? If you have the serial number, you can decipher it at this site: www.americanclassic.com/
Winona 1949 3100 5 Window Deluxe Cab
| | | | | Joined: Sep 2004 Posts: 17 Junior Member | | Junior Member Joined: Sep 2004 Posts: 17 | THE VIN TAG IS GONE.IS THERE ANYWHERE ELSE TO GET THE VIN ON THIS TRUCK? | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 |
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Ralphy, I hesitated to comment on the first link you gave above because I know you have a lot of original documents. The link above has some information that does not match what Chevy Duty has in its brief run down of distinctive features of different AD truck years. I do not know much about differences between 47.5-49 but I think that a little of the 1954 Chevrolet Truck model information is incorrect (I think). For 1954, the following information is questionable: # Indented passenger rear fender for side mounted spare tire [ ? on driver's side in 1953-1955.5] # Automatic Transmissions available along with a rare open drive line rear end [ ? closed drivelines with all 1/2 ton truck transmissions in 1954 - open driveline in 1955] # Horn mounted on intake manifold [ ? horn changed in style (clamshell ?) in 1953 and was mounted on the intake manifold; the new-style horn was mounted on the radiator housing in 1954] It is possible that some of the information from year-to-year was cut-and-pasted and might be questionned. Nonetheless, all the 1947.5-1949 information at the link might be correct. As stated above, the Vehicle ID plate would have been the most useful item for dating the truck. As most of us are painfully aware, ID plates, and most other parts, have commonly been changed over the years (even though we have been assured that everything is stock). Tim | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | How about lever shocks? They were 45-48 only as well, right?
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Tube shocks were introduced for the '50 model year, I think. | | | | | Joined: Sep 2004 Posts: 17 Junior Member | | Junior Member Joined: Sep 2004 Posts: 17 | IT HAS LEVER SHOCKS,BUT I THINK TUBE SHOCKS DID COME OUT IN 1950.IT MUST BE A LATE BUILD 48 I GOT THE TITLE AND IT SHOWS A 48. | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Have you checked the engine casting date? The date is cast into the engine behind the starter. You may have to remove the starter to see the number. My 49 rolled off the assembly line in late April of 49. The engine was cast April 19, 1949.
| | | | | Joined: Sep 2004 Posts: 17 Junior Member | | Junior Member Joined: Sep 2004 Posts: 17 | i will look at that,thanks | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | 48Chevy,
Rear cab mounts on 47-48 used a shackle arrangement under the center rear of the cab and had solid rubber blocks over the frame rails. 49 up used shackles on each side of the frame to the outer sides of the cab floor.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Sep 2004 Posts: 17 Junior Member | | Junior Member Joined: Sep 2004 Posts: 17 | LOOKS LIKE MINE IS A HALF BREED.IT HAS PARTS INDICATING A 48 AND A 49.I HAVE A TITLE FOR A 48 .WHAT YEAR WAS THE FIRST 5 WINDOW CAB? | | |
