| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 26 'Bolter | | 'Bolter Joined: Jun 2015 Posts: 26 | After cutting away the badly rusted outer vent covers, the inside also has rust. And some rust-through spots. I'll be patching the rust through spots obviously... I'd appreciate advice/insight on one thing, though... Should I return to the sandblaster to remove the rust and then repair, or should I seal the rust as is? This won't be a show car, it's to be a daily driver. http://i.imgur.com/4DTx2Vi.jpghttp://i.imgur.com/hljLNoy.jpg | | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | If the blaster is available, I'd go that way now that you have it exposed. Although the rust doesn't look that deep in most spots, I'm not sure I'd trust the rust conversion stuff to take care of it for the long term.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
