| | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 3 New Guy | | New Guy Joined: Apr 2016 Posts: 3 | I have a 53 GMC 9300 and want to swap the rear end so I can change it to a 5 bolt and newer driveshaft as I'm going with an automatic trans. Anyone have advise on what newer rear ends would fit size wise. it will be a daily driver to and from work | | | | | Joined: Jul 2015 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 37 | Somebody has a list here of compatible rears for these trucks. We looked high & low for a 1970-82 Camaro rear at 62 in width but they are getting very hard to come by. A guy in Fla had a 12 bolt and wanted 1200 for it in pieces. Depending on what width your rear is wheel mount to wheel mount you want to stay as close as possible to your width . After doing considerable research we found that the s10 4x4 ZR2 10 bolt 8.5 ring rears work good and start at 400 bucks. they come with 342 or 373 gearing limited slip or posi. They are easier to find in salvage yards. The width on a ZR2 is 63.125 wheel mount to mount....close to our 62 in width on our 1955 1st series truck. We are going to have custom wheels made so we will adjust the 1 inch offset. The standard s10 4x4 is shorter ...about 59 inches. We also considered the Ford explorer rearends but wanted to stay with the Chevy becauses the Explorer has 3 in axle tubes. BTW the outside axle tube on our trucks are 2 3/4...... the s10 is 2 1/2 and the Ford explorer are 3 in. You have to take that in consideration if you are running stock springs due to U bolt and lower shock mount plate hole sizes and locations. TCI has custom spring kits for about 600 dollars to change over any rear you use but lowers the truck 3 inches. The ZR2 is also disc breaks from 1998 up, we went to disc on front with a mustang 11 IFS so the ZR2 rear worked out good for us.
| | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | I recently completed a rearend swap on my '52 3100. I used a RE from a 71 Nova and rebuilt it to include posi. The width was perfect. New shock perches had to be welded but that was no problem. I paired it with a T5 tranny and love the combination..
1952 Chevy 3100 Semper Fi !
| | | | | Joined: Jul 2015 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 37 | Did you have someone do your drive shaft fit up in Ga.? I live in Ellijay and need a drive shaft made....thanks | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | | | | Joined: Apr 2016 Posts: 3 New Guy | | New Guy Joined: Apr 2016 Posts: 3 | I have a 53 GMC with a wheelbase of 116" the question is it a long or short box | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 116" GMC 1/2 ton one-piece enclosed driveshaft would be a short box. | | | | | Joined: Apr 2016 Posts: 3 New Guy | | New Guy Joined: Apr 2016 Posts: 3 | thanks for the reply I was thinking it was a short box
