| | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11602 04/06/2002 5:53 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | This is a 4 barrel offy dual port. But what is it for. Doesn't fit Chevy or F@*d but is sam length as Dod@e slant six, but tangs are in wrong place. I figured I would bring it to the "brain trust". Numbers on the bottom are - 6154. Offy intake
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#11603 04/06/2002 6:31 PM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | Oly I can't see the pic. This comes up when I connect to the site "You are not authorized to view this page"
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
#11604 04/06/2002 6:34 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | I know- somebody is adding a new wrinkle on me somewhere. Or my brain(?) has expired.-LOL
#11605 04/06/2002 6:55 PM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 |
*** GMC ***
#11606 04/06/2002 8:34 PM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | wel i added it to my album Oly try and see if it will come up here http://www.webphotos.com/woodhick\'s pics
#11607 04/06/2002 8:43 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | woodhick, yer having the same problem I am. Does the picture show above?
#11608 04/06/2002 8:55 PM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | Oly yes it is above. Go to webshots and then click on community the type in woodhick's and see if it comes up that way Thanks Fred
#11609 04/06/2002 9:13 PM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | I see it just fine. It look jeep to me. Make a trip to a junk yard and see if you can match it up.
if it dosen't need fixed, break it
#11610 04/06/2002 9:52 PM | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | Looks like the OHC 6 pontiac used in Tempest and Firebird . Engine available as a 1 bbl or 4bbl from 66-69 | | |
#11611 04/07/2002 6:36 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Oly, pix is in my veiw on your post. Is Offenhauser still around? diff name? Can you use the #'s to ask them what it's for? Or someone like Patricks or In-liners.org have old catalogs from them?
On that Pontiac idea....shouldn't it have GM and a part # on it if they used? Rarely did they use the vendors Labels on parts of their vehicles. What's the deal on those old OHC engines? I've never heard any good about them, I've never really seen one upclose either. Are they just a Chevy block and diff head? Why/where did they break all the time? Anyone still have a running one? :confused:
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
