2 members (R&S 51 GMC, Tiny), 152 guests, and 2 robots.
Topics128,125
Posts1,056,338
Members48,440
#1160065 04/13/2016 1:05 AM
What holds the wiper transmission arm on the wiper arm tab under the dash. Is it a rivet or a shoulder bolt? My truck is a 58 apache with vacuum wipers.
Big Bolt Forum Moderator
on the motor end, or the end at the pivot? This holds the arm on the pivot pin at the motor end.
http://www.americanclassic.com/images/WW803.JPG
Mike
The pivot end. Someone had put a bent nail holding the drivers side. The passenger side is on but I can't tell what is holding it.
it is a ball and socket. Here is a picture of mine. I can go take one from a different angle if you want.
http://i1152.photobucket.com/albums/p494/69B-Cuda/wiper%20pivots_01.jpg
Mike
Is the ball and socket where the link rod joins the arm shaft?
It sounds like one of the "pins" on the bar is missing if a nail is being used to hold the transmission on. If you aren't comfortable with that, you need a new motor or yours repaired by having the bar replaced.
On the vacuum wiper motor, the transmissions are held on by a single spring approx 2 1/2" long that has eyelets on both ends and when installed it stretches between the 2 "pins" on the bar. The 2 pins are grooved for the eyelets to ride in keeping the spring from moving up or down the pins. It slips on over the arms and the tension will hold the arms on.
The part that shown on the American Classic page is for electric wiper motors.
PM sent
1959 3100 Apache Fleetside
sorry for not seeing this earlier, ball and socket on the end of the arm.
Mike
Moderated by  ndkid275, Phak1
