3 members (Otto Skorzeny, Materman, 55shaker), 61 guests, and 1 robot.
Topics128,079
Posts1,055,941
Members48,430
#1159900 04/12/2016 4:05 AM
So I took out the fuel sending unit,it was bad as expected. Looked inside and tank was rust covered. Did a search on here but didn't find anything in first 5+ screens of search for gas+tank+clean. Any advice? No local places seem to do this anymore. One place said I can get vinegar or muriatic acid and do it myself (they only sell replacements). But also said just keep it full, no sealing required...
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
52vff #1159918 04/12/2016 11:03 AM
I have used both the acid and molasses cleaning methods both with good results. I am certain there are still shops that can professionally clean and seal the tank, search your area for "oldtime" radiator shops as they often can perform this type of work.
Lots more pictures
52vff #1159933 04/12/2016 12:47 PM
If your truck uses the behind the seat gas tank you might be better off purchising a new tank.
Rockauto.com sometimes have in stock spectra brand tanks for AD's made in Canada
52vff #1159979 04/12/2016 5:39 PM
Try this thread from 2010:
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/658153/Rusty_gas_tank.html
My tank is perfect on the outside, but the gas went bad inside and fouled it. I plan to do some version of the "gravel tumble" and reseal it, but don't have a tractor with big enough wheels!
NHluvstruck...
1951 3100 5-window
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
Moderated by  ndkid275, Phak1
