| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | So I took out the fuel sending unit,it was bad as expected. Looked inside and tank was rust covered. Did a search on here but didn't find anything in first 5+ screens of search for gas+tank+clean. Any advice? No local places seem to do this anymore. One place said I can get vinegar or muriatic acid and do it myself (they only sell replacements). But also said just keep it full, no sealing required... | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I have used both the acid and molasses cleaning methods both with good results. I am certain there are still shops that can professionally clean and seal the tank, search your area for "oldtime" radiator shops as they often can perform this type of work. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | If your truck uses the behind the seat gas tank you might be better off purchising a new tank.
Rockauto.com sometimes have in stock spectra brand tanks for AD's made in Canada
