3 members (DoubleB, Chip O, JW51), 173 guests, and 4 robots.
Topics128,077
Posts1,056,016
Members48,433
#115944 07/28/2004 7:40 PM
Junior Member
Junior Member
I have some holes rusted out in my fenders. Should I patch them with metal or fiberglass or is this a personal pref.
Thanks for any help
Paul
Paul
When you do a good deed, get a receipt just incase HEAVEN is
like....the IRS
#115945 07/28/2004 11:23 PM
Cut out the effected area(s). Use metal patches.
Unless, you wan't to keep performing repeat repairs. Just my opinion.
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
#115946 07/30/2004 10:13 AM
Don't forget the rust is about 3-4 times bigger than the hole on the back.Be sure to get all the rust or when you weld it will blow through.Fiberglass if you want a temp repair.
48GMC 5window,350,700R4,p/w,p/b,and a couple of homemade parts!
41 Sedan Delivery next up to be reborn!!
"Nothing is Junk,just unfinished projects" Desert rat with a spray gun!
#115947 08/10/2004 7:45 PM
Use metal. Fiberglass will be a waste of time....unless you really want to fix it again in six months to a year. wink
Joe K.
1963 Chevy Stepside
350 with 3 on the tree.
1960 Chevy Bel Air
35k original miles
1991 GMC Syclone #1557
1992 GMC Typhoon #0261
#115948 08/13/2004 10:36 PM
I haven't done body work since my 65 Impala in 1970. Back then I used bondo after grinfing off the rust. I need to repair rusted fenders, doors, truck!!! Is it best to dip strip first and then have new metal put in, or does it matter? Also, should I sand blast or dip? Just which is best and what is the sequence of steps? I don't want to do anything twice....
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver
1929 **** Model A Pickup - Restoration
