3 members (TUTS 59, WICruiser, 1 invisible),
125
Mod | | | Forums66 Topics128,090 Posts1,056,382 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | As my truck gets ever so close to start spraying color, I am starting to spend more time on details. Was noticing a few scrathes on the stainless hood strips. They are not that bad that they couldn't be polished out, but was wondering if they could be sanded first to save time. If so what grit would be recomended. Thanks : Stuart | | | | | Joined: Feb 2003 Posts: 33 Junior Member | | Junior Member Joined: Feb 2003 Posts: 33 | Stuart, When I do my polishing I start with 180 grit wet/dry.then go higher and higher 320/400/600/1200 by the time you get to the 1200 its pretty shiny already then when you buff it it comes out mirror smooth,it takes some time but once you see how nice it is you'll be happy with it.you can save some time by starting with the finest grit that will still do the job. Greg | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | Thanks Greg I will give it a try | | |
