7 members (Gdads51, joe apple, 78buckshot, Hanks custodian, Otto Skorzeny, 1955 1 Series, Rexville48),
122
Mod | | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Will need an electric fuel pump for my 58 GMC 1/2ton truck 270 6cylinder. Any recommendations?
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I would recommend looking into why the mechanical fuel pump isn't sufficient. Why do you "need" an electric fuel pump? Carl
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Here's a reason: I have two GMC Zenith carbs on my 235. Over a period of weeks not running, the gas evaporates or leaks out of the float bowls. Then, to start it I have to pull an air cleaner and prime the carb with a little gas. What a pain! So I bought an inline electric pump at the swap meet and installed it in place of the mechanical pump.
Problem solved. That is until the alcohol in the gas ate up the plastic insides of the pump and I was back where I started. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | What size pump would I need?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I dimly recall that cletis has been using a disguised electric fuel pump in his truck (for several years). Maybe he'll offer suggestions/information?
In terms of "size" pumps, you need a gallons per second number.
1958 Chevrolet trucks fuel pump ratings (GMC would be similar, I'd guess): 3.5 - 5.5 psi for 6 cylinder 5.5 - 6.5 psi for 8 cylinder | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Install a Carter mechanical fuel pump and your problems will be solved. With a good mechanical pump (translation: NOT AC!) it shouldn't take more than about 5 seconds of cranking to fill a completely empty fuel line. Jerry
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | roger 52carl and Hotrod Lincoln, you dont need electric, mine went(235) out after a few yrs and I replaced it with one from NAPA,seems like mine was about $26 drove that sucker ever day and 1100 mile trips, purred like a kitten Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm with Jerry and Fred on this, the mechanical pump is all you really need. I have stock replacement type pump on mine, made by Standard-Blue Streak, it has no problems feeding the dual Holleys on my 235.
Bill Burmeister | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | I dimly recall that cletis has been using a disguised electric fuel pump in his truck (for several years). Maybe he'll offer suggestions/information?
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Thanks 4 the size info...
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Tim, I think you ment to say 1-gal per minute, not per second (that would be a big pump at 60 gpm). Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Just divide by 60 or multiply by 60, depending on your "reference" units, Mike. I don't think I gave a specific rate (vol/min etc) - just a pressure in PSI at the carburetor (from the Spec Man - at 1800 RPM, I think) http://chevy.oldcarmanualproject.com/chevyresto/58t110.htmWhat would be the rate in GPS (or, in GPM)? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | OOPS, my bad Tim, I miss read you post thinking you said he needed a pump rated at 60 gps. Senior moment AGAIN...lol, sorry. Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That's OK, Mike
What would be the Gallons Per Minute spec for a standard fuel pump?
Thanks.
Regarding electric fuel pumps:
Do all electric fuel pumps need some sort of return (or, some sort of pressure relief/release)?
FWIW: I have no problem about switching to an electric fuel pump (6v or 12 system), but I have never had a need for this. My 261s with dual carbs (or a bigger single carb) have never had a fuel "starvation" problem (at start-up or at full throttle) - with original-style fuel pumps.
And, my trucks have never had a significantly slow cold-starting problem (waiting for gas to reach the carb). As I post every Spring, my Suburban starts every Spring - no problem with fuel getting to the carb/carbs, and no problem with the 6v battery (11 years old) being ready-to-crank after hibernation. I do have to crank a little longer for the first post-hibernation start, and I do have to be careful not to flood the carb/engine.
I check all the tightness of all the fuel-line fittings at the beginning and end of the "driving season", and I use a fuel stabilizer before hibernation. Maybe I am just lucky. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The main reason I went with electric was because of vapor lock problems. Here's the story. | | |
