2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I was at a wrecking yard today and they have an old Ford U-haul truck (my guess is late 60s or early 70s). It has 22.5 rims that look like 6 hole Budd wheels. I was wondering if anyone knows for certain if they are the same as the ones on the GM trucks? I think they do and it might be worth getting for someone here who needs some! Left rear outside had an 8-22.5 tire on it, LF had no tire, but wheel was there, could not get around to the right side but I think all the tires and wheels were on that side. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Same. Likely 6"x22.5" wheel which takes a 9R22.5 tire at largest.
I just bought a set of them off a 60's Dodge | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Grigg, what is a fair price? I can check with them on a price and pick them up if someone wanted them. I bought a full set with almost new tires on them for 900$ for my 58. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | 6 hole stud piloted interchanged between Ford, Dodge and GM in the 50's and 60's. I'm not sure about later ones. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Fair price, depends on if you need them or not and if you have to remove and dispose of the tire.
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Thanks crenwelge, that is what I thought, but wanted to be sure.
Grigg, I don't need them, I have 10 wheels at the moment (4 came with my truck, and I bought a set of 6 with tires) and the guy I bought my 58 from found another one for me, it is about a 3 hour drive to go get it though so, it is still over there! I was just at the wrecking yard today and saw them and figured if someone needed them, it might be worth snagging them. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The ones I bought I have no use for I just felt sorry for them sitting in the junkyard year after year. Removing the old stiff heavy tires was quite a chore, ended up cutting them off, not sure even a good tire guy would have had much luck with just the bars/irons. In any case they're good wheels and worth saving if the price is right for you and your situation. | | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Concur with Grigg. Grigg, if you still have extra wheels with the 6-lug pattern, we have a new guy who will be needing them (we brought his truck home yesterday with scary RH-5's on it. Scary even for RH-5's ...) I'll send him to you offline.
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | Some of the ford rims ran a 20 inch wheel | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I have removed a lot of junk tires from old rusty wheels. I lay them flat with the lock ring up and knock them down as much as I can with a duck bill hammer. I then pour on as much Diesel as I can. In a couple of days, it will soak all the way down and make the tire pretty simple to remove. It is a lot easier than cutting them off. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'll try that on the next ones, thanks for the idea,
Grigg | | |
