11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible),
109
Mod | | | Forums66 Topics128,056 Posts1,055,789 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I'm working on my 55.1 grille. All components require repair, most notably those fat "middle" bars that bolt to the side of the nose piece. The l.s. middle bar didn't look like it fit right and after awhile I realized it is different! I'm guessing it came off a larger truck. But I'm stuck with it and either have to repair it and use it as is, modify it to look like original (a lot of work) or find a suitable replacement. I'm thinking these grille parts are rare. Any ideas? | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | Thanks! I will check with Jim Carter's. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | What middle bar are you referring to?
| | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | My grille has a top bar that curves downward at the end. "Chevrolet" is stamped into it. The next level has the wider bars I refer to. They fasten to the nose piece in the center and they also fasten to the running light housing. The last part of the grille is the bottom level which is essentially a pan.
These middle bars as I call them are curved upward at the back, presumably to direct air upward to the rad. I removed these upward curved sections because my rad is lower than stock and straight-through flow is better and less restrictive. I have an email in to Carter's to see what he has. | | |
