2 members (Otto Skorzeny, 1955 1 Series), 89 guests, and 4 robots.
Topics128,031
Posts1,055,436
Members48,422
I have a 51 1/2 ton that I am finally getting all the front end sheetmetal put back after being painted, and am having some difficulty getting things to line up.
The back corners of the hood need to come down some more, but even after reaming out the oblong hinge mount holes this doesn't seem to completely solve the problem. The hinges won't come down any more in these holes because of the contour of the cowl at this point.
The other frustrating problem is the front of the fenders need to come up and spread apart so that the front of the hood will fit properly.
Other than the rubber shims under the radiator support are there any other shims that are supposed to be used to make any of these adjustments?
41 Chev 2dr coupe
51 3100 w/a 261
11 Camaro RS ragtop
Do you have a shop manual? I believe that it addresses sheet metal alignment in there. Second do you have the fender to firewall braces?
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
mtdewman, it can be done, just take your time and think it through. Check out these pics of mine! There are ajustments for all of it.
