| | | Forums66 Topics128,116 Posts1,056,637 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Well this is something I didn't count on. My new tires are picking up rocks and denting my stepside wheelwells from the inside out. This was an old plummers truck and I worked hard and long on those wells to get them perfect. The stones hit with such force that they cracked the body filler. I am thinking about spraying the wells with some some canned undercoating to soften the blow. Certainly some of you guys have had the same problem. Any suggestions would be greatly appreciated.
delete my account and pictures
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I have the same problem Tab , I sprayed underseal on 1/16" thick , to no avail . I'm going to try to fabricate some brackets to hang some looong mudflaps from . I will try to get them up high under the fenders. | | |
