2 members (klhansen, Tiny), 232 guests, and 3 robots.
Topics128,077
Posts1,056,016
Members48,433
#1157022 03/27/2016 2:46 AM
I was wondering if anybody uses newer style 6 lug chevy wheels on their bolt. I searched this question but was unable to find an answer. I found some aluminum wheels off of an 03 suburban and am courius if they would fit. Any information would be useful.
Larry
After '88, GM went to a different offset/backspace on their 6 lug trucks, similar to what is found on FWD cars. Wheels for the later trucks will not fit on the pre '87 trucks without rubbing or using an adapter spacer to make them fit.
Bill Burmeister
Ok, thanks for the quick reply.
Larry
Larry, I've purchased wheels from trailer supply shops.
Chevies of the 40"s has a better supply/design it that's what your after
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
I put trailer rims on my 52 3/4 ton. So far, so good. Had to make sure that the center hole was the correct size as well though.
