1 members (baldeagle), 37 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#1157816 03/31/2016 5:52 PM
The speed part stop working remove from dash clean oil it,new cable.Bench tested work find.Install it work so so on the speed part. Does the gear part on transmission just screw out and need to be oil.At 75 i do not want be up and down a hundred
time
If the odometer is working correctly (drive a mile it adds a mile) than everything from the trans to the speedometer head is working as it should and your issue is in the head.
What year truck are you wotking on?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1157823 03/31/2016 7:24 PM
1950 3100 chevy It tested find on bench use drill low, high speed ran about a mile it
Is the truck drivable? If so hook it up and find a measured mile marker somewhere and see if the odometer is reading correctly. If it is than you know you have the correct driven gear and everything from the trans to the speedometer head is good.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #1157828 03/31/2016 7:44 PM
I think you are right ,i road test it mileage seem OK . The speed is off i will look for use one
